Bathroom Fan Fused at 3Amps | on ElectriciansForums
Discuss Bathroom Fan Fused at 3Amps in the Australia area at ElectriciansForums.net
Hello Guys
Just a quick question re Bathroom Fans and that some manufacturers state that they are to be supplied from a 3 Amp FCU
i have two Quries really that i just need clarification on if anybody can help.
1/ when the bathroom lighting is on a loop circuit ( and is supplying another room from the rose) Does the loop out from the bathroom rose have to be fitted to the supply side of the fcu and then onto the next light
2/or is it acceptable to leave it in the rose loop in even though the lights that it will supply will now be fused at 3A instead of 6A
but johnny if the supply to the next room is left at the rose it would be fused down to 3amps via the fcu, and if the fan were to develop a fault it would also take out all lighting supplied from the bathroom rose. by running the loop from the fcu this is avoided would you agree.
no just a normal fcu (3amp) to fuse lighting circuit down to 3amps for timer fan (as manufactures ins) Rcd protection provided at CU for entire lighting circuit. only wanted the fan and bathroom light to be fused down to 3amps, so running the loop out of the bathroom rose to supply side of fcu.
the fan im installing is a timer fan so i obviously need a swL,L,N. taking this from the bathroom rose to 3 pole isolator and then onto the fan. The manufacturer insists that the supply to the fan has to be fused at a max 3Amp rating. so if i insert a fcu(3a) on the bathroom lighting supply the fan will be fused down to 3 amps asits supply is fed from the bathroom rose. hope that makes sense
Souza619.... If you wish to advertise you need to become a forum sponsor .... its not a free service we provide as a forum, please contact the moderators to assist you if you wish to advertise or post links to companies websites.
I'll say it again, ....if the fan/timer ''NEEDS'' fusing down, then it should be provided and incorporated by the manufacturer of the unit. FCU fuses are NOT there to provide protection for equipment and accessories, they only provide suitable protection for cables/flex's!!
I couldn't agree more. Overload protection is the responsibility of the manufacturers.
If a fan needs to be protected by a 3A cartridge fuse then it says a lot about the confidence of these fan manufacturers.
There is some complete rubbish around in the market place
Agree with the above. However, when we are being told that to comply with regs we HAVE to supply via 3 amp fuse, and an electrician even went to prison when he didn't do so (regardless of whether a 3 amp fuse would have prevented the fire), it puts us between a rock and a hard place.
Reply to Bathroom Fan Fused at 3Amps in the Australia area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
