Bathroom Fan. Help. studying City and Guilds | on ElectriciansForums
Discuss Bathroom Fan. Help. studying City and Guilds in the UK Electrical Forum area at ElectriciansForums.net
mid wales
Hi. I have decided to put working fans in my bathrooms., replacing old ones which have not worked for years.
The trouble is I believe it is a ring circuit, incorperating the lights and fans.
One side of the ring cable connecting to this fan, had CPC Line and neutral, the other only CPC and line. No neutral cable at all.
This does not look right to me, Advise please?
These two pictures , (hopefully they will appear on this site) show two line, one neutral and a combined CPC of two separate sides of the circuit.
I will test this tomorrow thank you
[ElectriciansForums.net] Bathroom Fan. Help. studying City and Guilds
A little tricky to tell from the photo, but I think you have a Live, Switched Live and Neutral at the Fan to allow for a Fan with an overrun timer, but you have a fan that has no overrun timer and is just on or off.
The Live would need to be identified (safely) and put in a connector block, the Switched Live and Neutral connected to the fan
I get the impression of a separate switched live as well.
At a guess there's no isolator for the fan?
Reply to Bathroom Fan. Help. studying City and Guilds in the UK Electrical Forum area at ElectriciansForums.net
It would normally be the outer terminals where the flex of the pendant drop connect.
Rcd protection?
