P
pjlm
Hi everyone,
I recently moved into a new build house with a fitted bathroom complete with fan that comes on/off with the light switch (+delay for going off).
Strangely when you switch the lights on/off in the hallway next to the bathroom is sometimes disturbs the fan so you can hear it skip, or sometimes stop completely.
Recently the fan has struggled to get going, and pulses for a few seconds before getting up to speed.
Outside the bathroom there is an isolator switch and a fuse for the fan.
Is there an approved method for wiring up bathroom fans? Are they usually connected to the light switch, light or separate with a trigger from the switch somehow? I don't know where to turn to fix this so if there is a module somewhere I could replace or tighten that would be helpful
Could anyone give advice on what to try or likely causes? Any help very gratefully received.
thank you
Pete
thank you
Pete
