Bathroom fan stays on when cfl lamp is fitted | on ElectriciansForums
Discuss Bathroom fan stays on when cfl lamp is fitted in the UK Electrical Forum area at ElectriciansForums.net
O
oldtimer
Guys got a call this morning customer changed the lamp in the bathroom from a standard incandescent to a energy saving lamp and when he switched the light off the fan kept running so I asked him to check it with the lamp removed and the fan went off after 5 minute as it should.
So I have never seen this before anybody else had this.?
Had very same problem and have had problem with flo tubes when added a new fan, changed fan for xpelair problem sloved, cheap fans anit worth the bother now everything is going energy saving in my opion
Reply to Bathroom fan stays on when cfl lamp is fitted in the UK Electrical Forum area at ElectriciansForums.net
That does help, it shows that the problem is almost certainly in the way it is connected and not a problem with the fittings.
davesparks
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
