Bathroom GU10 downlights | on ElectriciansForums
Discuss Bathroom GU10 downlights in the Australia area at ElectriciansForums.net
U
Uncle Bullock
Hi folks.
Qucik qestion.Just moved to a new house and one of the downlights in the bathroom doeant work, ive changed the bulb but to no avail,can i change the fitting?..if so can you let me know what I need to buy and is it complicated to change it?
Many Thanks
It might not be the fitting. It could be a bad connection or something similar. Before doing anything make sure you have that circuit switched off. Pull the fuse or switch off the mcb ect. It is hard to advise without seeing the fitting. Would not cost much to get an electrician in. He should find the problem in no time.
Reply to Bathroom GU10 downlights in the Australia area at ElectriciansForums.net
Neutral and live
  • Poll
Hi Folks, I'm looking for downlights that satisfy the following criteria: (1) white bezel; (2) fire-rated; (3) IP65 or above; (4) anti-glare...
