Siren
We're in the middle of plastering the hall after the first fix and having seconds thoughts about the position of the bathroom light switch outside.
The electrician said its not too late to have a pull switch fitted inside the bathroom as it's still bare brick and no ceiling for wires to go in. That would be better but would spoil the look as you walk in.
Could we have a Light Switch sensor for inside the bathroom. If a pull switch is possible then one or both of these surely should OK?
Aquawave Bathroom Light Switch Chrome - AQUAWAVE - Aqua Wave Bathroom Sensor Light Switch - Doble Bathrooms
Or just a more simple sensor placed in the ceiling.
WHITE IP20 CEILING MOUNTED 360 DEGREE MOTION DETECTOR on eBay (end time 19-Sep-10 08:40:21 BST)
Either one will operate or activate a couple of downlighs, four probably, or eight tiny ones if the ceiling sensor is the one option in three rows of three, sensor in the middle.
