deridere
Hi all, I've been reading this forums for the last 5 years, but never registered as I always found my problem described by someone. Can't find exact description for the following:
Bathroom with 12V fire rated spot lights and mains powered built in timer in-line fan( Mixflo MF100T), to be controlled by ceiling mounted PIR with presence / LUX /timer control, and all this connected to 3 pole isolator. Fan is to installed in the loft above the bathroom.
What the best way to wire all this?
Idea is for the fan and lights to come ON when someone enters the bathroom, and stay on until no movement is detected( LUX control want be used at the moment). And then fan needs to continue running for pre-sett time.
Thanks for the advice.
