Bathroom tv | on ElectriciansForums
Discuss Bathroom tv in the Australia area at ElectriciansForums.net
Sttevo
Orite lads. New to the forum. So go easy. Currently rewiring my house. And mulling over the idea of a tile LCD tv. It runs of 12v requires a mains socket and isolator. Was thinking of putting tv on stud wall. Could the socket b hiden in stud wall and use the fan isolator for tv as well or would it need separate isolator. If separate where could I possition it as not to **** next to tv I.e pull switch next to LCD .
If the socket in the bedroom is accessible and switched then you wouldn't need an isolator. If possible I'd position the transformer in the stud wall behind the socket for future access. Hope this helps.
Reply to Bathroom tv in the Australia area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
