A
ANDREW B
What code would you give for a batten holder in a bath/shower room? I know that its zone dependant but I have been calling a code 2 for zone 1 and 2 even if it’s mounted on the ceiling slightly above 2,25m.
The batten holder then needs to be replaced with an IP rated fitting, this then requires a RDC fitting to the bathroom circuit opening a can of worms that may require a consumer unit upgrade.
On the other hand if an IP light was already installed and all bonding in pace, a code 4 regarding the RCD is all that’s required.
Any thoughts?
Any thoughts?
