Battery and Inverter installation | on ElectriciansForums
Discuss Battery and Inverter installation in the DIY Electrical Advice area at ElectriciansForums.net
NickXx
Woodville
Hi folks,
I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about the quality of the install:
  • I wasn't given any documentation, so no "part P" documentation.
  • Around three metres of new meter tails were added - running from the electricity meter to a new consumer unit which feeds the inverter. I think meter tails are double-insulated, so probably no issue there.
  • Those new meter tails are supported by cable ties - attaching them to a gas pipe which conveniently runs in the same direction.
So, am I worrying needlessly, or should I be concerned.
Thanks for your thoughts,
Nick
You have every right to be concerned. Under no circumstances should cables be tied to a gas service pipe. Have you contacted the company for certification?
Reactions: DPG
Thank you for confirming that. So far, I have written to them asking for clarification on what should happen with regard to Part P.
No response as yet, but it is the weekend.
Thanks again!
OK, things have moved on. I have also noticed that the meter tails that were installed in the meter cabinet have exposed inner insulation on several of the tails. I complained about that too. I have now been visited by a different pair of engineers. They made little comment, but fixed the issue with the exposed inner insulation. They also fixed the invertor properly to the wall - apparently a screw was missing. They also stated that there was no issue with the tails being clipped to a gas pipe, because the tails actually don't need to be supported at all.
I have also received a "Building Regulations Certificate of Compliance" which I presume is the long-awaited Part P. It just says "8002 - Install one or more new circuits". In my mind, I am comparing that with or recent kitchen extension for which we also got a very long document, a "Minor Electrical Installation Works Certificate" defining each circuit that was added, along with all the testing details.
Thoughst very welcome.
Thanks,
Nick
Reply to Battery and Inverter installation in the DIY Electrical Advice area at ElectriciansForums.net
We had a similar call out and the issue was with the grid (which they admitted). Voltage was too high.
Now had panels for over a year, and still no payment for export, made application to British Gas on their forms, but they say wrong format, it...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
