W
wattsup
I haven't seen such a system for many years not sure how they operate.
Anyhow got a call to find a fault on such a sytem, going tomorrow...
They say they have a bank of several batteries, when the building is empty they switch off, via a 20amp switch fed from local db. When the building is in use they switch on and all emergency lights are lit maintained (about 30).
Now when they switch on, none are working....
Seems a crazy system...all wired in micc.
Would the 230v supply, feed a contactor/relay or a trickle charger for the batteries, or both?
Anyone know anything about this sort of set up?
I will advise to update to latest methods but I'm sure the costs would be a factor.
The building does have a current fire regs cert, inspected yearly including em lights and fire alarm
