Battery Charger from DC Motor | on ElectriciansForums
Discuss Battery Charger from DC Motor in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
A
andrex
Ive got a 24Vdc motor on my wind turbine and Im trying to use it to charge 2 sealed batteries 12Volt in series. Ive been searching the web for days for a circuit/product to regulate and charge the batteries but cant find anything.
Can any one help?
You'll need a charge controller that can dump the excess to a heat dump (aka looks like an exposed kettle element !) one fo the most popular (and inexpensive) is the Morningstar TriStar battery charge controller, these guys: Morningstar | Wind & Sun Ltd. can supply you everything you need.
Reply to Battery Charger from DC Motor in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
The contacts are pushed open by a cam as the shaft is turned so they operate quite slowly. That's fine on AC as any arc is self-extinguishing at...
Hi, I previously read this but can’t find it. I have drilled some holes but haven’t found it yet. Before I instal the wires I thought I’d check...
