Battery charger manual/wiring diagram needed | on ElectriciansForums
Discuss Battery charger manual/wiring diagram needed in the Electrical Tools and Products area at ElectriciansForums.net
ackbarthestar
Mentor
A Zoo near YOU
Does anybody know where I can get hold of SIP 25082 Startmaster P500BCT Professional Battery Charger (with Timer) wiring/circuit diargam. A client of mine has dropped this one on me, so to speak and I said I would sniff around and give him some feedback on whether or not I can fix it.
By the way I was trained under the RTFIF school of fault finding.
I know its a specialist item which is likely to be difficult get information, so any guidance will be helpful.
Thanks in advance guys
Reply to Battery charger manual/wiring diagram needed in the Electrical Tools and Products area at ElectriciansForums.net
Pasted from a previous thread: A source for everything to do with French electrics is here: Norme Ă©lectrique 2013 2015, Amendement A4 normes NF...
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
