Battery Powered Programmable Room Stats | on ElectriciansForums
Discuss Battery Powered Programmable Room Stats in the Central Heating Systems area at ElectriciansForums.net
topquark
Mentor
What cable do you guys run if you're newly installing a Battery Powered (no neutral reqd) Programmable Room Stat 6242 or 6243 (future proofing)?
Cheers
Martin
or even better as some donkeys have done 5 core flex run 10mtrs under floorboards,jokers:61:
Arrghhh, no! I will be putting a (somewhat redundant) wiring centre in tomorrow, just so I can take some heat resistant flex into the boiler :) .... As my 16mm stat feed was a bit stiff (now you know why I was penny watching) pmsl ;)
Reply to Battery Powered Programmable Room Stats in the Central Heating Systems area at ElectriciansForums.net
Sounds more positive.
I am living in the north of Thailand outside of the big city. That means in the rainy season we have multiple times per week power outages...
