Things are getting more complicated as things progress. Have talked to Andy at Sibert about this a little. Just wondered if anyone else has much experience with this.
Both work off a CT clamp. How would you set up a hiearachy of use and ensure both devices don't fight each other? In all cases background use is first priority. You really then need to decide whether priority is battery or hot water, which may be dependent on how water is heated or need to turn off boiler in the summer.
Thoughts please.
Incidentally, we are still in business and quite busy - mainly new build projects and maintenance.
Thoughts please.
