baumatic oven | on ElectriciansForums
Discuss baumatic oven in the Australia area at ElectriciansForums.net
sparkyb2
right heres one, changed my oven thermostat but still not working, any ideas as its a selector switch and the grill works ok off it , but can get no joy on my oven, dont think its the element thats faulty as its a single oven.
Single oven element at back of cooker, remove the back plate inside the oven its self...Have a look, if no joy slide oven out (after safe isolation) and remove rear housing you will see the cables going to the element. Also i know it sounds stupid but make sure time is set or not flashing as oven will not work
Ash
grill is working and thats the oven element as well is,nt it
grill is working fine and the element at the top of the oven is the same as the grill isn,t it
Reply to baumatic oven in the Australia area at ElectriciansForums.net
how long have you had the oven? Could be that the heating element has blown. Which happens after a long period. Is everything ok on the...
Cbelectrics
C
