This is long shot but worth a try. Went to the mentioned boiler as the pump overrun was running continuously. Everything pointed to the pcb so I replaced this with the same model. It worked correctly when I fitted it ie. The pump shut off after roughly 5 mins. The customer called today to say the pump is running all the time again? Anyone know what may be causing the pcb to fail like this?
The system works as it should and there is only a switched live when the valves open before anyone suggests a faulty valve.
