I am replacing some bedroom lights for my girlfriends parents, their old ones stopped working, they where built in LED bulbs with a live and neutral coming from the fixtures, so I am replacing them with newer lighting fixtures, it is straight forward, put the cables into the relitive parts but when i switch it on nothing happens, I have replaced the light switch, trimmed back the conductors (in case of damage) and tried a new fixture I had just bought (didnt work) but still, when I wire them up they just dont seem to work.
they have told me that the guy who lived there before was a bit of a bodger but I just dont understand how the lights worked just days before but now they just dont?
Any help would be appricated,
thank you
Start with the obvious... check your consumer unit that an RCD hasn’t tripped.
They are designed to trip if you touch a neutral.
Thank you for your reply. I did check the RCD, It blew like you said, when I touched the neutral. I switched it back but still, they just don't work, all MCB's and RCD's are on at the point of switching.
If they all stopped working at once there may be something else going on, so it's likely a case of getting back to basics.
If each light only had one live and one neutral, and you've replaced them, the chances of you incorrectly doing every one are slim, so it's likely somewhere else that the problem is.
Pictures of the back of the switch might help, it might be a loose neutral behind the switch, or at a junction box somewhere - Is there a central ceiling light, or was there at one time? If so then there may be a loose wiere there, or in a junction box that replaced it.
It's hard to troubleshoot further without some sort of voltage indicator (and an idea how to use it safely), to see whether power is actually getting to the bedroom in the first place.
This issue has been fixed - the problem was that the guy who wired the lights spured off of a socket below the lights, in the trunking next to the socket was a fuse that had blown, I was unaware that this was even a thing so I didn't think to look at it, you live and learn.
thanks for your help guys.
A fuse in the trunking? Any pictures? Sounds like maybe someone has used an inline fuse to fuse the lights down maybe.
was thinking maybe a FCU fitted. that is the correct way to spur lights from a socket circuit. fuse in FCU should be no more than 5A. but I'd sack the painter.
Eastbourne
United Kingdom
Trainee Electrician
Bedroom lights not working
Daryl93,
telectrix,
