Bedroom Wall Sconces | on ElectriciansForums
Discuss Bedroom Wall Sconces in the DIY Electrical Advice area at ElectriciansForums.net
Ajboynton
Frisco
I am installing two wall sconces in my primary bedroom on either side of the bed. The staright up install isn't an issue but then again, I can never just install something normally. My goal is to have a switch on each side of the bed that can turn on both lights, turn off the light on the switch side or turn off both lights. I am wondering if there is a single switch that works this way. I can do a standard 3 way switch but then they are both either on or off. I want them to also be able to be on independently. Any ideas?
Reply to Bedroom Wall Sconces in the DIY Electrical Advice area at ElectriciansForums.net
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
My guess from that last picture is the whoever installed it has drawn two 6242Y’s instead of a single 6243Y for the 2way side of that two gang...
