Best AFDD board as of Nov 2020 | on ElectriciansForums
Discuss Best AFDD board as of Nov 2020 in the UK Electrical Forum area at ElectriciansForums.net
Zerax
Wiltshire
So if a customer really really wanted a board with AFDDs in... what's the best RCBO/AFDD solution out there right now ? I can only find Crabtree and Wylex, but I guess there must be others now too ?
Not seen any other practical solutions, the last time I looked the Eaton versions took up 3 modules each. Never fitted any before though as the price is so high compared to a standard RCBO setup.
Reply to Best AFDD board as of Nov 2020 in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
