Best Ariel System | on ElectriciansForums
Discuss Best Ariel System in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
M
martinxxxxxx
I need to supply and install a freeview antenna system to four rooms in a large house. Fairly good reception area. What system including a loft booster would you recommend.
What arial is best
What booster is good.
Do I need to have better that Tower cable.
Thanks in advance
Martin
What arial is best
Thanks in advance
Martin
A log periodic aerial
Simply Aerials & Satellite
and one of these
MAST HEAD AMP UHF, 4 WAY, 10DB - PROMHD14M - PROCEPTION
Works a treat
And a digital box in each room
CT100 coax
Reply to Best Ariel System in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
C
Small rental portfolio advice please. With the up and coming Renters Charter, its probably time to start thinking about increasing the efficiency...
Chris Taylor
C
To be honest I am in NC and I’ve always used old blankets to cover all my well and never had a problem. Much simpler and has worked every winter...
