Best cable cutter for meter tails | on ElectriciansForums
Discuss Best cable cutter for meter tails in the Electrical Tools and Products area at ElectriciansForums.net
not cheap, but effortless.
cheap if you'retight-fisted.
Ratchet cutter would be a bit labourious for this size of cable.
210mm CK croppers - cheap, cheerful and slice through 25mm2 copper with ease.
240mm are a bit cheaper, if you have bigger hands.
Reply to Best cable cutter for meter tails in the Electrical Tools and Products area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
Best tile cutter Hay there, Need a new tile cutter 600 minimum, I’ve used one from topps tiles which was ok, but I need to upgrade that’s why...
