Best consumer unit | on ElectriciansForums
Discuss Best consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Best consumer unit. Been a while since I have done a lot of domestic work. What's best consumer unit for domestic installs . Taking into account price and availability. Probably been asked many times. Any help would be very much appreciated. Cheers
I think most customers are willing to part with a little extra for a Fusebox RCBO board rather than a double the price Wylex RCBO board, even though it’s in their best interest.
As above, the SPD is a game changer, and the 32mm knockout is conveniently located on the side of the DB where the main switch is, instead of the middle, makes installing tails that little bit easier.
I installed a dual RCD board in a rental property where the landlord didn’t want to pay extra for the RCBO board and the existing cabling for the RCDs is super flexible, again making installation that little bit easier.
Loads of space for cables, and the front cover aligns quite nicely and easily, which some boards don’t.
Build quality seems decent, although the main carcass didn’t seem as solid as a Wylex. Only thing I can think of to grumble at.
The Fusebox, Wylex and Crebtree compact RCBO all have neutral-switching 'DP' action, which makes testing easier and helps if you have a TT system where you might want an up-front delay RCD.
Other sound, if more expensive, options are Hager and Schneider.
Going all RCBO generally make life easier for you as well, less chance of spurious trips and less impact if they happen. Need to look out for borrowed neutrals in up/down lights, just as you would if lights split over a dual RCD board, but that ought to be checked/fixed on any sort of upgrade anyway.
Arrived this morning.
[ElectriciansForums.net] Best consumer unit[ElectriciansForums.net] Best consumer unit[ElectriciansForums.net] Best consumer unit[ElectriciansForums.net] Best consumer unit[ElectriciansForums.net] Best consumer unit
Complete with tails gland as well.
  • [ElectriciansForums.net] Best consumer unit
Reply to Best consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
Regulation 534.4.8 SPD installation shall preferably not exceed 0.5m and in no case exceed 1m
thank you it really made me feel small, maybe i played it a bit thick, but as the one needing the work done i was cap in hand, will try another...
Could someone kindly share why the SPD unit must be in parallel? I'm confused sorry! Hard to say without a basic wiring diagram of the current...
6K
