F
freedomrun
DOMESTIC, TN-S, 60A DP switch, BS3036 5A fuse, no RCD, customer wants an Bathroom Extractor in 13" outer wall. I was gonna run some plastic mini trunking from IP44 light fitting to pull switch, Mount Isolator switch outside Bathroom on wall. Only need to RCD protect this part of the cct - any suggestions, also this is not in London - how much do you think i could charge seeing as it's old Victorian with quite thick walls. I'm gonna use a 20 quid fan, or something on offer around that price.
