best option? | on ElectriciansForums
Discuss best option? in the Australia area at ElectriciansForums.net
northern ireland
hi folks- right in a factory there r 15 floodlights outside supplied from 3 different boards around the factory 5 on each board, above each board is a hand off auto switch, contactor and time clock, the owner wants the lights to come on at dusk so i was thinking photocell, and he wants them to go off again around 11 when the factory is closed. is wirin 3 photocells back to each board the best option or is there a easier cheaper solution?
put the photocell on as the contactor controll circuit with the timeclock set limclock to switch off at 11pm so breaking contactor circuit. then get it to switch on in morning sonmetime but the photocell will keep the circuit open till its dusk.
i would keep the over ride in as well.
as you said most of its there its only a photocell to put up for each board.
was speaking to client 2nite again and now he says he was speaking to someone who told him that he he could operate his lights with a keyfob remote control to turn them on and off does any one know of this sort of system and where i could find out some more info. thanks for replies so far
Reply to best option? in the Australia area at ElectriciansForums.net
It sounds like the company involved in the works doesn't have the necessary expertise to undertake the task A company that specialises in this...
I went with a partner. We're able to support each other and take time off knowing the other is at the helm. We split all profit 50/50 whether we...
