Best PAT tester | on ElectriciansForums
Discuss Best PAT tester in the Electrical Tools and Products area at ElectriciansForums.net
B
Bright.Spark
Im after a PAT tester which will opperate on battery and test 240v and 110v. Which tester would people recommend?
Hi, You say you are looking for a battery powered tester, check out the Seaward Primetest and the Martindale HandyPAT ranges also. I can recommend the Seaward Primetest 350 and Martindale Handy PAT HPAT600 in particular.
Be aware:- Although having a battery power PAT tester appears to be a plus point and attractive feature, it does have a big minus point, one that can seriously effect you potential income, notably the inability to do run tests. Most industrial and commercial contracts I see frequently specify equipment run tests, particularly those from the MOD, NHS, Local Authorities, Schools, Colleges and Universities.
Reply to Best PAT tester in the Electrical Tools and Products area at ElectriciansForums.net
Hi We are looking for someone full time, PAT experience not a necessity. If you have some electrical knowledge background, as we would want you to...
KT66EVA (KT66DL & KEWEVA) - ÂŁ1073.60 + VAT if you shop about as a combo
