ninemaverickbars
Hello everyone,
Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work today, installing a surface fixed metal faceplate and back box. When terminating to create the spur (tight fit into terminals with both 6mm and 2.5mm!), I noted that the previously installed 2 gang metal plate and back box did not have an earth fly lead.
Because I don't really know any better, I tend to use an earthing fly lead where the faceplate and back box are both metal, or just the back box is. I understand that there is often a common earthing rail within a socket, allowing for it to be earthed via the screws into the back box. Perhaps the fly lead is therefore redundant?
The socket I installed was a 1 gang MK unit complete with back box, metal as I say and it had a separate earth terminal for connection of a fly lead. The 2 gang socket however, did not have a separate earthing terminal.
My question is, when it comes to metal faceplates and back boxes together, or metal back boxes with a plastic plate, is it always best practice to use a fly lead, or generally better not to unless the socket has a dedicated terminal for it?
I hope that makes sense as a question and isn't opening a can of worms.
Many thanks
Many thanks
