Best storage heaters | on ElectriciansForums
Discuss Best storage heaters in the Central Heating Systems area at ElectriciansForums.net
All electric system, no gas in village presently hot water supplied by an aging oil fired Rayburn. About to install solar panels and electric heating. What storage heaters do the panel recommend. What are Stiebel Eltron like? What about RC wave any advice appreciated. Have Dimplex in the old pad bit clunky
Fitted a couple of replacement Stiebels recently - 30 odd year old originals that they replaced were German made, identical model replacements were Chinese made. I have to say build quality looked identical. A far as heated boxes of bricks go, they are well priced and well put together. Much cheaper than the equivalent Dimplex models.
Why would I be worried about that, the customer specified I just put in a cu & radials + fitted heaters.
But as you asked the manufacturer claims they are more economical that storage heaters (so the landlord tells me)
Fahro heaters, easily the best replacement for night storage, very low running costs
Expensive, but the running costs easily outweigh the running costs of night storage, and they look pretty modern
Henley block installed and some new tails installed into the night store board from the 24hr supply, jobs a good-un
Reply to Best storage heaters in the Central Heating Systems area at ElectriciansForums.net
My guess is that you'll need to have your existing re-jigged as you've probably got a separate consumer unit fed from the time clock side of your...
