Best Way to Add a Light in the Loft | on ElectriciansForums
Discuss Best Way to Add a Light in the Loft in the UK Electrical Forum area at ElectriciansForums.net
am549
East Midlands
I've got a new build property and it looks like the electrician has left some wiring in the loft ready for a plug socket to be installed (2.5mm twin and earth cable). I'm assuming it's for a plug socket due to the cable size and that it's not wired into any of the lighting circuits (checked by switching off all the lighting circuits and the cable was still live according to my voltage pen).
What would be the best way to wire in a light? I've got some 1.0mm twin and earth cable which I'd like to use so my thought was this:
Install double socket off the current cable
Use the 1.0mm twin and earth to wire a pendant into a 3 pin plug with a 5amp fuse installed and plug it into the above.
Based on the above, would I be able to wire the plug into a junction box in order to feed 2 pendants? Thanks
Are you saying the 2.5mm cable is live but not wired to anything?
Firstly, standard 13Amp plug tops are not designed to accept twin and earth cable of the type you are describing.
The cable you describe as 2.5 mm2 cable, have you any idea where it is fed from?
Where are you in the East midlands? if it's not to far from me I may be able to offer some practical help.
Are the cables for the lights in the rooms below the loft not in the loft? Where is this wiring? or am I missing something....
They are but covered by the loft insulation and I didn't fancy taking it all up and taking a spur off it.
This spare wire is attached to a roof truss. (see attached photo).
[ElectriciansForums.net] Best Way to Add a Light in the Loft
I've got no idea exactly where this random live cable is fed from, only that it appears to be wired into the upstairs sockets.
Can't see the photo
Reply to Best Way to Add a Light in the Loft in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
