Best way to extend a single back box into double on already tiled wall? | on ElectriciansForums
Discuss Best way to extend a single back box into double on already tiled wall? in the UK Electrical Forum area at ElectriciansForums.net
edinburgh
Customer wants 1 single socket outlet turned into double point on his kitchen wall which is tiled already with single box hole cut out
Is it best to measure out the space required to fix double back box , drill multiple holes around the edges and go round it with angle grinder diamond disc?
Or would cutting straight with angle grinder work?
More of an industrial elec so haven’t dealt with this job before in a house
Multi-tool with carbide blade.
Not cheap, though.
Done this a few times. Best way to do it is to cut the tile, and as deep as you can go, with a 115mm non serrated diamond disc in an angle grinder and a very steady hand. Once the tile has been dealt with, drill all four corners to depth with a masonry bit (not through the tile), then chisel out the rest.
Warn the customer that there will be lots of dust that will penetrate the whole house, and that there's always a possibility that the tile will crack.
There are some kind of device plugged into any outlet giving 4 or 6 receptacles, even a housewife can install it. The only trouble is cosmetic, this device sticks out of the wall by about 1 inch.
I uses it a few places in my home.
Reply to Best way to extend a single back box into double on already tiled wall? in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
