Southern Spark
I am starting a rewire of a 4 bed maissonette next week. The meter and original c/u is by the front entrance, but the client wants it moved up to the first floor, which will then be near his front door. I want to keep the supply C.S.A at 25 mm, and obviously I will be incorporating a switched fuse to protect the supply, but I was wondering what is the best type of cable to use... the overall length of run is about 15 - 20 m, it will be run under floor boards for some of the run and coming up the wall in a cupboard. Is it ok to use normal tails for this?? I have never seen it done before like this. In the past I have used 16mm T and E, but like i say, there is a lot of heavy loads on the circuits, so I would like to keep it at 25mm, thanks.
