Bg weatherproof rcd fused spur | on ElectriciansForums
Discuss Bg weatherproof rcd fused spur in the UK Electrical Forum area at ElectriciansForums.net
South Wales
Hi guys
I installed this unit protecting a shed for a customer a while back and he’s text me with images showing the fuse burnt and it’s holder melted. All connections are tight and no moisture inside.
Any ideas why?
Also I’m hoping to replace this spur with a more reputable brand within its existing weatherproof box.
I'm far from being the brains of this operation, but there has been quite a bit of discussion around the subject of plugs/FCUs with fuseholders that provide inadequate connection to the fuse. Your situation seems to fit, but it would be interesting to see the pictures.
Hi guys
Any ideas why?
What size and type of fuse??
Thanks for the reply.
[ElectriciansForums.net] Bg weatherproof rcd fused spur
  • [ElectriciansForums.net] Bg weatherproof rcd fused spur
Standard 13a busman fuse
Feeding few sockets, 2 x 18w led battens. I’d imagine a heater has been plugged in.
I'd say the heater has been plugged in for extended periods. 2x 18w leds would not cause that sort of heat unless there is am extremely poor connection over a long period of time.
Thanks everyone for the replies.
I’d guess it’s a combination of poor quality rcd spur and a heater or like you said a hot tub over a sustained period.
From the BG data sheet, the incoming L seems to go to the bottom of the fuse, so given the problem happened at the top of the fuse, it's not loose cable termination (as if!)
Faulty accessory and/or overload🤔?
Reply to Bg weatherproof rcd fused spur in the UK Electrical Forum area at ElectriciansForums.net
