Hi,
I’m an industrial electrician, so when it comes to DB regs and such my experience on them is a little limited.
I need 2 x 16A 3 phase supply and 4 x 230v 3 pin sockets which is intend to do as a ring however, the nearest supply is approx 120m away! Running this through a cable calculator I’m being advised to run 16mm cable in.
I’m wondering if I’m allowed to put a consumer unit in about half way, and have each circuit ran from there?
This would be fed from a 100A supply DB. About 80A occupied but I’m unsure on being allowed a consumer unit from a db? Any additional info on how to tackle this would be appreciated like domestic regs an industrial lad wouldn’t often come across.
