F
fotlong
has anyone ever terminated a 400 mm 4 core swa how hard and how much space do you need
Do you mean a big switch panel? cables enter from pit below.... where do they terminate into? Hope its not awkward to gland in, that would make life tough...! You may struggle more with bending the cores depending on what space you have. Also you will need a very big crimping tool to get the lugs on.... You can hire them from most wholesalers if you dont already own one.
I hope you’ve got 18” stilsons for the glands. Once the glands are made off then there’s the fun of the core terminations.
Re: big cables
Won't need the Stiltons, if he uses those bolt on tube glands
but i think pump pliers as opposed to stilsons - they won't get near it.
Theres a bit on top hat glands here CABLE GLANDS, TOP HAT GLANDS, 11KV SWA CABLE GLANDS, HV GLANDS, CAST INTEGRAL EARTH GLANDS, 6.6KV 33
