Probably all in a days work for a professional electrician but it had me scratching my head. I wanted to fit lighting into a room but there is an en suite on the floor above, as you can see I made a hole in the ceiling and worked from underneath.
Discuss Bit of a challenge for me in the UK Electrical Forum area at ElectriciansForums.net
What size cable is that? only it looks a bit bulky for lighting applicationsProbably all in a days work for a professional electrician but it had me scratching my head. I wanted to fit lighting into a room but there is an en suite on the floor above, as you can see I made a hole in the ceiling and worked from underneath.
Looks like 2.5 T&EWhat size cable is that? only it looks a bit bulky for lighting applications
Yeah me as wellLooks like 2.5 T&E
Click Mode (for White) with Fan Module & Fuse Module would fit onto a 1 gang box.Is there a three pole switch with a fuse to make a neat finish in one plate does anyone know
Is electrical work in a bathroom subject to Part P notification in England?bathroom??? RCD protection???
A pat on the back to say he did a good job I presume, and saved a few quid on a sparky in the processI have no idea what the OP wants to know.
Reply to Bit of a challenge for me in the UK Electrical Forum area at ElectriciansForums.net
