C
confused-fuse
full set of blank forms just use open office to open them or use exel
PIR,MWC,DB,EIC,EM-Lighting
Discuss blank forms in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
How do you enter the info if the cable is imperial stranded?
The only problem with drip-down boxes in Excel/Openoffice is that you do not have the option of entering your own info - why is why I prefer to enter info manually...................
Reply to blank forms in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
