Discuss blank plate within 300mm from the cooker? in the DIY Electrical Advice area at ElectriciansForums.net
Its about 300mm above it, and right on the edge. Half and half.How close to the cooker is it I have two right next to mine.
Just had a look. There is a connection point on the box. So connecting it to the earth and joining the rest of the cables with https://www.toolstation.com/connector-strip/p19539 connector strip 30A should be fine. Just need a blanking plate which fits inside the box and not over it. Have you seen any? Worst come to worst i can just make one.If you fit a metal plate ensure you connect the earths to the blank plate.
Wago is good, but pricy, i think i will just make a cover from steel plate so it will be earthed. and tile over it. Thanks for advice!I would recommend Wago connectors and yes if you use an all insulated plate connect the earths to the back box, if a metal plate connect to the earth terminal of the plate. You will not find a plate whick fits internally to the box.
That is a bad idea concealing electrical connections behind a tile.Wago is good, but pricy, i think i will just make a cover from steel plate so it will be earthed. and tile over it. Thanks for advice!
Well, i can not leave it as it is because its in the red zone of my cooker. I have two EMT coming up to it from the floor i guess (so its part of the loop). And EMT is buried under the screed. So my idea is connect wires for continuity and cover it. As i can not leave it in the red zone. I am open to ideas guys.That is a bad idea concealing electrical connections behind a tile.
Most of my cables are in the EMT buried in the screed. If something goes wrong i think it will be the case of rewire without pulling old wires out (don't think any of them will come out, or new could be pulled through) and running new circuits .If the connections are hidden then they must be maintenance free types, not connector blocks. Also, you will be losing the 'prescribed zone' for your buried cables. Unless there is something else in the same vertical or horizontal line.
Please heed the advice others have given. Don't leave something dangerous that may catch someone out in years to come.
Reply to blank plate within 300mm from the cooker? in the DIY Electrical Advice area at ElectriciansForums.net
