Discuss Bleed valves on electric towel rails in the UK Electrical Forum area at ElectriciansForums.net
try putting it in upside down .When you fill the radiator - you put water in and the air has to escape to make room for the water!
Thanks Dave was writing at the same time. Customer is questioning me and I have said that it's a closed system so no point in bleeding as no way to top back upNo there is no need for air bleeds, yes you do normally leave some air space and they normally have some sort of corrosion inhibitor added to the water.
Yes, but in 5 years time, when the element fails, someone will need to drain down the rad and replace the element. Then refill the radiator from the top. It's somewhat inconvenient to have to take the whole enchilada off the wall to do this.Meant to say these are prefilled full of water/inhibitor so turned upside down to fit element. They come with 4 x blanks installed but do have a bleed valve in the pack which I'm guessing is for CH systems
Think he thinks they will explode
I'm talking purely from a safety point of view, to do what your suggesting would require a bleed valve on the bottom of the towel rad as a drainage point which imho isn't really what they are designed for. I can see leeks in the future but stand corrected if this isn't what you meanYes, but in 5 years time, when the element fails, someone will need to drain down the rad and replace the element. Then refill the radiator from the top. It's somewhat inconvenient to have to take the whole enchilada off the wall to do this.
Stick an 18L expansion vessel on the wall and flexi to the bleed valve port.Think he thinks they will explode
Reply to Bleed valves on electric towel rails in the UK Electrical Forum area at ElectriciansForums.net
