Bloody Wood Butchers. | on ElectriciansForums
Discuss Bloody Wood Butchers. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
as above. fitted a wall cabinet. drilled , plugged and screwed directly above mid point od a double socket. what a muppet. esp. as the cabinet brackets could easily be moved a couple of inches.
[ElectriciansForums.net] Bloody Wood Butchers.
Don't complain...it keeps you in beer tokens!
On the landing of our house, the previous people stuck a nail about 12" directly above a light switch..Luckily it is patrician wall and the T&E wasn't hanging dead vertical otherwise they would have nailed it!
Crikey Pete I thought you were on about my Wife, her name is Patricia.:Do_O:rolleyes::)
That wouldn't have happened if the cables were bodged in diagonally. It is me, or is it only sparks that seem to be aware of cable routes....tho in this case your socket was directly below and bloody obvious!
it would seem that logics dictate cables go straight up/down/left/right. we all know that. trouble is that some other trades can't see anything beyond their own incompetence. ( and that excludes the other trades that have a brain, some are good, some bad, some indifferent, and some should have been smothered at birth).
Try this one on for size ...
... screw in 'free' space, not fixing anything, ~ 15 - 20 mm from the edge of the edge of the back box hole and roughly vertically in line with where the cable sheath and conductor insulation has been breached! Lath and screw 'plastered' over with 'new' white plaster ... certainly not the original lime plaster!
... and then there is the 'stripping' damage to the insulation on the other side of the Line conductor! If I remember correctly that was the 'load' cable. It was not connected to anything ... but the 'supply' cable was connected to a MCB @ the Distribution Board.
Try this one on for size ... View attachment 40551 ... screw in 'free' space, not fixing anything, ~ 15 - 20 mm from the edge of the edge of the back box hole and roughly vertically in line with where the cable sheath and conductor insulation has been breached! Lath and screw 'plastered' over with 'new' white plaster ... certainly not the original lime plaster!View attachment 40552
Looks like the electrician stripping those cables had a bit of a mishap with the red conductor, more than likely he was using a Stanley type knife.
Reply to Bloody Wood Butchers. in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
