Blowing breaker | on ElectriciansForums
Discuss Blowing breaker in the DIY Electrical Advice area at ElectriciansForums.net
Cmuehling
Il
I have a very small circuit in my house. Probably 8 outlets 6 lights. The breaker for this circuit has a direct short somewhere. It didn't start this way. At first it would stay energized for a couple of minutes then trip. The more I reset it the shorter it would last. Now it trips immediately. I can sometimes see an arc when I reset it. I have replaced the breaker, I have removed three of the light fixtures and pulled out 6 of the outlets from the wall to inspect them. I removed one of the outlets. Besides removing all of the fixtures what is the best way to troubleshoot the problem. I should mention that most of the light fixtures have 2 or 3 way switches.
The fact that you have been repeatedly closing the breaker when there's a fault condition means it is probably now in need of replacement. You will need an electrician to do some testing to see what the original al fault is.
Reply to Blowing breaker in the DIY Electrical Advice area at ElectriciansForums.net
Loose neutral somewhere… possibly at panel or at the last light before it goes to panel. You say you’re getting power through the switch and up...
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
