C
cldcp00
I have a extractor fan in the kitchen which has been working fine. It is powered by an isolator switch on the wall which has a fuse in it and a power on indicator light. Recently it keep blowing fuses in this isolator switch. It does not blow them straight away it seems that after the fan has been running for a while it blows the fuse. I spoke to the manufacturers of the fan as it is less than year old and they have told me that the problem is not with the unit but with the supply.
I did notice that the indicator in the fans isolator switch was flickering where the one in the Washing machine was solid.
Could somebody advise me what I need to do
