Blowing sockets and popping RCD | Page 7 | on ElectriciansForums
Discuss Blowing sockets and popping RCD in the UK Electrical Forum area at ElectriciansForums.net
London
A client asked me to add two sockets in their bedroom
I took power from two sockets in the lounge which is behind the bedroom wall.
I ran a cable out of each socket for the new socket
The problem is it now is tripping the RCD and blowing the old Existing sockets and light switches
But the new sockets I added still work fine
The old existing sockets and switche are blown and unusable
When I try to reset the RCD It pops and Sparks down
Any idea to why this is happending
I didn't know that there is a new x1 AC RCD test ? How does that work compared to the old one ?.
In short, just omit the x5 tests.
I still test at x 1/2 for both waveforms as I want to know it’s not overly sensitive and then the required x1 on both waveforms.
Now Auto mode is less useful i tend to test all of them at 1/2 and then all of them at x1 to avoid fiddling with the tester too much.
I think it's still a requirement to ensure they dont trip at 50%
Worth remembering that 7671 is a minimum, if you want to carry on using auto and doing 0.5x 1x 5x and Ramp then there is nothing stopping you.
The cynic will say that the 'new' testing regime may be "better" but then we remember that OEMs are on JPEL64 and would favour the reduced testing as it would result in fewer returns
Agreed, and circumstances dictate what's worth doing.
Ramp tests are certainly useful for lots of situations.
But even under the old regime if a modern RCBO tripped at under 40ms on the x1 test then increasing the current for a x5 test is never going to slow it down and IMHO it was a pretty pointless test in a lot of cases.
Reply to Blowing sockets and popping RCD in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
