Blown fuse | on ElectriciansForums
Discuss Blown fuse in the UK Electrical Forum area at ElectriciansForums.net
London
I live in a block of flats and the fuse in the ryefield board to my flat has blown. If there was a fault with my electrics in my flat would the fuses in my consumer unit trip or blow too? The power went out and my consumer unit was fine all the MCB’s and RCBO’s stayed on so I’m just curious if that means it’s not likely to be a fault within my flat and possibly just an old Ryefield board fuse? Someone is due out but I thought I’d ask just so I understand what’s happened better.
Main fuses don’t just blow for no reason.
The cable must run from the rye field up to your flat…. Is there any chance this has been damaged? Might be clipped on wall and easy to spot.
It is possible, but highly improbable that you can overload the main fuse without overloading any individual circuits…. But you would have to be pulling an awful lot of load….
If someone is coming out, they should do a little testing before just replacing the fuse. Hopefully they find something easily fixable.
Reply to Blown fuse in the UK Electrical Forum area at ElectriciansForums.net
Hello all. I have been asked to fit a Ryefield board and switch-fuse on an existing 3 phase supply so that a shop can have its own meter and 3...
For a TN system neutral is deemed at earth potential.
