Automatic stock saw. Coolant pump fed from the same contactor as the main motor but via MD 2A fuses instead of an O/L relay (the main motor, stock advance motor and hydraulic pump all have O/L's). Ate the fuses last week, tested the pump motor for IR and winding resistance, all good. Ate the fuses again today, replaced them and disconnected the main motor intending to clamp the leads and listen. Powered up, pump ran 10 secs, made a clunk and ate the fuses. So I think there's something inside jamming the impeller from time to time.
I want to sort it before I go home. Snag is, I've got to undo four nuts in here to get it out...
