Blown Lights | on ElectriciansForums
Discuss Blown Lights in the Talk Electrician area at ElectriciansForums.net
C
carlos180
Hi, doing some diy in the house, knocking off some plaster, my fusebox popped and my upstairs lights will now not work, tried switching the switch back on in the fusebox, and it pops and knocks back off, could this be a fuse problem ??
Forgot to mention, there were cables under the plaster, not boxed in, some numpty had just buried them :(
It's a cable problem, sounds like you've caught a cable, you need an electrician to locate the fault and repair/replace the damaged cable.
Always isolate your supply when doing such building works, you could easily have had a shock.
Sounds like you'll need to get an electrician in to start replacing the damaged cables. If the fuse is blowing it's not a fuse problem, it's a circuit problem.
He may be a numpty for not using a safe zone ( if that were the case),but burying cables is an industry recognised installation mathod
When chopping out walls, its very important to check that you are not chiseling into a safe zone willy nilly
how do you know you have not "squashed" them and created a dead short inside the Grey rubber insulation!! looking at the outside is misleading and with out the correct test equipment you cant be sure
suggest ring a spark!! will probably cost you ÂŁ50 for his time!
Reply to Blown Lights in the Talk Electrician area at ElectriciansForums.net
Neutral and live
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
