Blown low energy bulbs | on ElectriciansForums
Discuss Blown low energy bulbs in the Australia area at ElectriciansForums.net
P
pburley
Hi A friend (plummer) as done some work on a newly completed block of flats (I think about 10 flats) he said that all the low energy bulbs keep blowing, he said that he thinks they all need new transformers. I have not been round yet to look, but I thought you guys may have some ideas to get me going. Ta.
First thing I would check is that dimmer switches have not been fitted. Most energy saving bulbs do not work with them unless they are so designed.
Secondly, loose connections will cause arcs which will decrease the lamp life.
Finally, as you state it is all houses on a new build, I have worked on similar where the client supplied inferior products...
regards
Reply to Blown low energy bulbs in the Australia area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
