Builders broke ground today with the digger down the side of the house. They busted a lead water pipe which runs down the side of the house.
Houses are fed in bunches of 5 from the street. That means me and 4 other houses share the same stop tap.
Builders repaired the T joint and replaced with blue pipe. Seven trent have turned up and spoke with me, they said if it was their house, they wouldn't feel happy building over water mains joints. However after talking some more they said the joints are made to last forever so it contradicted what he said.
I'm a little confused if it is safe or not. There is now a mix of lead and blue pipe which will be under the 2 storey side extension.
Anyone had any experience with these connections and how durable they are? Would you build over them?
