theoretical question:
if the main fuse is a 80A BS88 type IIb, tails are 25mm with 16mm earth, can i install a 10 way dual rcd board with a 100A main switch?
how is the total load calculated? all the MCB'sin your average 10 way bpard add up to way over 100A?
