Not a question, just an observation.
Working on a kitchen refit in a bungalow, up into the attic to find the ring circuit for sockets.
Came across a spur joint box, the J401 type with 3 terminations inside.... count the cables, 1, 2, 3..... 7!
7 x 2.5mm t&e in to one joint. Has to be a record...
Spoke with customer; "sort it out", "ok"
Safe isolation of supply procedures followed to the letter. I proceeded to disconnect the cables.
6 of the cables were actually only 3. The grey sheath had been carefully stripped off, about 100m length... The live and neutral had then had their insulation stripped to expose the copper. The cables then bent into place so the bare copper was in the terminations.
Someone took an awful lot of time to carefully remove the sheath and the insulation from 3 cables, for absolutely no reason.
