Hi just looking peoples thoughts on this one. I went to check out a 3 channel hortsmann time clock. I found it to be faulty as the display came and went. It’s about 12 years old and apparently when the internal battery fails it time to change the clock as you can’t access the battery.
Anyway, I removed it from the wall with the view of getting a new one within a couple of days but thenguy in the house now tells me the external boiler still runs.
Upstairs heating, downstairs heating and hot water controlled from the time clock. Each circuit has an individual stat and valve. With the clock removed the boiler shouldn’t of been getting a call signal.
I’ve to go back and fit the new time clock but I’m confused as to why the boiler still fires up. Perhaps a faulty valve? But then the valve should of been getting a signal as the time clock was removed. The back plate of the time clock does appear to be wired correctly.
One of the 2 port valves is likely to be faulty, sending a call for the boiler to fire. As the valve won't have opened the only way to identify which one is it is to test for 230v on the core used to call the boiler from the 2 port valve- usually orange but some people do use the grey.
Boiler comes on after time clock has been removed from wall
hoover,
davesparks,
